Help with 996xt
wc8i
Marion, Ohio
I purchased a GPS for my 996xt now it works but my question is do I have to pre program the scanner for it to work when I'm traveling ? Any help will be appreciated if possible can u send me the info at nbohioham@yahoo.com god bless Bill
kma371
If your using software, which I hope you are or I suggest you do, you need to set the radius for each system you want to monitor.
It's easiest if you import from the DB here as they should already have radius's, but you must be premium subscriber.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
wc8i
Marion, Ohio
So can u explain how to in software program
So can you tell me how I do that in the software program where do I look for that at to check the radius is of the for the GPS thanks Bill WCA guy
wc8i
Marion, Ohio
I am a premium subscriber and I do use the software program and I did download the the Freq around me from the database but how do I set the radius in the software program when I'm so when I'm driving it automatically monitor the frequencies thanks Bill
kma371
It's from within each system. Top right area of screen I think. There's s check box
kma371
Unfortunately this is the only area where FreeScan is lacking - it really doesn't fully support location based scanning. However, ProScan and ARC-XT do, I think. The links for both of these are here (anything blue is a link)
Uniden DMA Software Support - The RadioReference Wiki
What is Location Based Scanning?
Location Based Scanning - The RadioReference Wiki
And there's a section on this in the Easier to Read manual....
Easier to Read BCD996XT Digital Scanner Manual
HTH...Mike
Not sure where you got that information from but that's what I use and it works fine for me.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
FreeScan cannot, yet, process points of interest, location alerts and other options available under Location Based Scanning
Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Sorry, I meant to say Points of Interest, Dangerous Roads nor Dangerous Crossings, all of which fall under the LBS umbrella. There's a section on it in the Uniden TWiki and in the Easier to Read manual.
Hopefully at some point Assaf will add these so it more fully supports LBS ...Mike
