HELP with ABQ trunk freqs.
Croaker90
corpus christi
What freqs. Do I use to put in the Talk Group ID's on
http://www.radioreference.com/apps/db/?sid=257
Site Name
002 Primary 01 866.22500c 02 866.47500a 03 866.73750a 04 866.95000 05 867.20000 06 867.47500 07 867.71250 08 867.95000 09 868.23750
003 Primary 01 866.25000c 02 866.56250a 03 866.76250a 04 866.97500a 05 867.25000a 06 867.60000 07 867.97500 08 868.26250 09 868.50000 10 868.75000 11 866.11250 12 866.45000 13 866.71250 14 867.06250 15 867.45000
Which Primary do I use?
Is there alot to hear on the ABQ scanner? I have aPro-97 so I will get all "A" and some "M".
What about TORRANCE county, is there alot of good stuff in TORRANCE county?
Thanks, Croaker.
I'm going to be there a month and want to SCAN!!
abqscan
DataBase Administrator
Moderator
AOA
Program site #3 into a bank, that will let you monitor APD/AFD Dispatch. I'm sure you already understand that you will not be able to monitor any of the officers in the field.
I don't know what you mean by "good stuff?" in Torrance County, but here is the link to the DB http://www.radioreference.com/apps/db/?ctid=1822
Croaker90
corpus christi
Ok thanks,
On the Torrance Co. Freqs. what is this
155.77500 155.08500 WNZR890 RM Critical Infrastructure Services FM
What is the " Critical Infrastructure Services"?
Thanks.
P.S. What is SITE #2 and SITE #1?
Thanks, Croaker.
