Help With APX6000 P25 Non-Affiliate Scan
Beau_Zuver
Holiday City
So I recently acquired a APX6000. I would like to be able to listen to my local agencies that has switched to P25 (MARCS). I'm not sure how this all works. I'm a radio Tech in Ohio and I can do conventional stuff all day but truncking is not my strong spot. Some people tell me I can do this and some say I cant. But how do I program it to NAS?
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
I would suggest reading this thread and following the links in it...
n3obl
ØAES-1056
PA
So tried yesterday on fb groups and got shot down. Im sure there are MARCS techs lurking here also.
Thunderknight
Bletchley Park
Skypilot007
Medford, NJ
Skypilot007
Medford, NJ
You need to research this on your own and figure it out like the rest of us did. All the information you need is out there, start searching and you will find it. If you're really a radio tech it shouldn't take you long. First and foremost, hope you purchased a compatible radio flashed properly. That would be (should be) the first step in your research. Have fun!
Beau_Zuver
Holiday City
So let me put it this way then? what is the difference from a radio set to RX only and NAS any different then a scanner that is going to do the exact same thing. I understand that a scanner doesn't have the capability at all to tx but what would be the difference if its the same concept.
