Help with Avoiding on an SDS200?
tnbound
Middle TN
When I have to avoid multiple TGID's is the scanner actually skipping those id's or scanning them anyway and slowing the scanner down?
Whiskey3JMC
Just another pesky scannist
Simulcastylvania, TE
I never found avoiding multiple TGs slows down scanning any. How many sites are you scanning at the same time?
GTR8000
NY/NJ Database Guy
BEE00
The scanner doesn't "scan" through talkgroups as it does with conventional frequencies. It decodes the control channel and looks for talkgroup grants. If a grant matches something you have programmed in ID Scan mode, it tunes to the appropriate traffic channel. If a grant matches any un-avoided talkgroup in ID Search mode, it tunes to the traffic channel. It will simply ignore any grants for talkgroups that have been avoided, either temporarily or permanently.
GTR8000
NY/NJ Database Guy
BEE00
Again, it's not "scanning" the talkgroups, it's sitting on the control channel waiting for grant messages related to talkgroups that are programmed and are not avoided. It's a nearly instantaneous process, regardless of whether you have 1 or 100 talkgroups programmed or avoided.
tnbound
Middle TN
Quite a few most of the Tennessee TACN System plus several conventional groups.
Ok good explination thanks
