Help with becoming a feed provider in Summerville SC
brothersman
Summerville, SC
I have been doing some research and want to become a feed provider for the city i live in. I have a high speed internet connection, with a desktop i dont use. I need a scanner but unsure what kind I need for my city police band. Also I live in the heart of the city, so do I need an external antenna to put on the roof? I have used scanners years ago, but that's before this digital and trunking stuff came out and now its all a blur.
I live in Summerville SC, dorchester county, and I would like to broadcast Summerville Police Department.
Thanks fof your help in advance!
brothersman
Summerville, SC
oH wow! thanks for being so helpful, I couldn't have done it without u!!! seriously so where does it tell me exactly what kind of scanner i need for my police band?
scanphreak
You're in luck. Summerville is using the Palmetto 800 mhz trunked system, which happens to be a Mixed mode system. Meaning they cater to both analog and digital radios. Summerville happens to be using Analog. So you won't have to spend a lot of money on a digital scanner.
Palmetto 800 Trunking System, Various, Multi-State - Scanner Frequencies
this link is the database you'll be referring to when programming in your stuff. Just get any ole analog trunking scanner, and put in the control channel frequency for Summerville which is in red it's (858.76250) and set the scanner to control-channel mode only. The scanner will do the rest. Then all you need to do is program in the TALKGROUP for each agency channel you wish to listen to. The talkgroup is the DEC number listed below. So to listen to Summerville FD you'd program in 14896, or if you wanted to listen to Summerville PD Dispatch you'd program in 14928, and so on. In trunking, the TALKGROUP is like a channel number for whoever you're listening to. The trunking system randomly assigns a frequency to the talkgroup at any given time. The trunk-tracking scanner is able to follow along with the system. So all you need to worry about is the talkgroup id in the DEC field. Program it how you like and follow Mike's link to how to become a feed provider...
Summerville City (Dorchester County) Talkgroups
DEC HEX Mode Alpha Tag Description Tag
14896 3a3 A Smvl FD Summerville FD Fire-Tac
14816 39e A Smrvl FD FG1 Summerville FD Fireground 1 Fire-Tac
14768 39b A Smrvl FD FG2 Summerville FD Fireground 2 Fire-Tac
15024 3ab A Smrvl FD FG3 Summerville FD Fireground 3 Fire-Tac
15184 3b5 A Smrvl FD FG4 Summerville FD Fireground 4 Fire-Tac
14928 3a5 A Smvl PD Dis Summerville PD Dispatch Law Dispatch
14864 3a1 A Smvl PD Tac Summerville PD Tactical Law Tac
14832 39f A Smvl PD Rec Summerville PD Records Law Talk
14880 3a2 A Smvl PD Narc Summerville PD Narcotics Law Tac
brothersman
Summerville, SC
AWESOME thanks for all your help! Your have been a great help!
check back in a few weeks and i will be a feed provider for Summerville SC
W8RMH
Feed Provider Since 2012
According to Radio Reference Terms of Service you can't feed these talkgroups
scanphreak
I never suggested that he do that. I was just pasting all of the information for his city from the database page. I'm sure he'll read the terms and rules for what he can and can not broadcast. And back to the original thread topic, Brothersman, yes the PSR-410 will suit you just nicely since as I pointed out, the talkgroups you'd be feeding are all ANALOG TRUNKED.
brothersman
Summerville, SC
Yes I was just pointing it out to him.
Yeah my feed application got denied and I think it was cause of those channels. So I can only broadcast this channel?
NOT THESE RIGHT?
W8RMH
NOT THESE RIGHT?
If you are going to provide a feed you should really read the Feed Provider Terms of Service.
I personally would never agree that I had read something as important as this (which you had to do to submit your application) without even reading it.
This is the first paragraph:
Feed providers agree to ONLY broadcast routine dispatch and special events channels and talkgroups for law enforcement agencies.
I agree to NOT broadcast dedicated tactical, car-to-car, SWAT, narcotics, detectives or any other channels or talkgroups that are not routine dispatch or special events related.
