Help with deleting a conventional freq in PPS
kc9neq
Illinois
I created a profile with a conventional vhf frequency and P25 system, not knowing that the radio would not monitor both.
Can someone tell me how to delete the vhf frequency. I can't figure out how to do it.
When I select the delete function, it doesnt work.
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
You probably already know this, but the frequency really doesn't matter if it's not used later in the profile, assigned to a knob position.
Have you tried adding a frequency--it will default to another freq--450mHz, in the case of my UHF model. You should then be able to delete the frequency above it.
kc9neq
Illinois
The vhf freq is not assigned to a knob position and I have not tried to add another vhf freq.
lebrunmn
I'm sorry, perhaps I misunderstood what you were asking... there will always be at least one frequency on that D2 screen--that is why your "Delete" button is grayed out. In your case, you probably started out with a default freq of 136mHz for a VHF model. In my case the default is 450mHz for my UHF. Either way, there is always at least one line of data in that screen.
Hope that helps.
