Help with GO Transit on a Pro-197
maxtracs
Hi can someone tell me what happen to go transit I can not hear the buses the talkgroups are quit can someone help plz I'm using a pro 197
A lot if not most of the talkgroups are using P25 phase 2. The Pro 197 cannot monitor phase 2 traffic, only phase 1. If you wanted to listen to phase 2 you need a phase 2 capable radio like a Uniden 436 or 536 HP
mciupa
Canadian DB Admin
Moderator
Your scanner has some value if you put it up on Kijijii. It could help finance a newer Phase II capable radio if GO Buses are important for you to monitor.
maxtracs
Go transit
Ok so they still work because I was listening to them in kitcherner ont and now nothing is anyone having trouble or is it only me sorry
mciupa
Canadian DB Admin
Moderator
What conventional? They are trunked.
Your scanner is outdated for GO Bus. You need a scanner that does P25 Phase 2
Your scanner only offers P25 Phase 1
Talkgroups in the database have now been changed toT for GO Bus.
ATCTech
No, there is no voice channel decoding software out there yet for using your PC to listen to P25 Phase 2 transmissions.... sit tight, it will happen someday.
