Help with HT1250 Programming issue
Bpd119
I just programmed my ht1250 UHF i am having a problem with the first few words being cut out on recieve. it doesnt seem to be breaking squelch early enough. is there something i could tweak or whatever
i have played around with the tight normal squelch function and it doesnt seem to be helping thanks
bezking
On the Road
Could be a couple things.
Are the other radios using MDC1200, Quickcall, or DTMF signalling? If the other end doesn't wait for the signalling beep to stop before they TX (or the radio techs didn't program a sidetone, which I think would be silly), the forst word or two could be cut off.
Also, are you using PL? If you are, try putting it in CSQ for RX and see if the problem goes away...
Bpd119
hey thanks for the reply. we are using mdc and its a post mdc. i am using a PL i will try the CSQ now.
thanks
ramal121
Lots and lots of watts
Calif Whine Country
Also go to MDC menu, DOS tab. DOS auto mute duration should be zero as this feature is not used for post tx ID.
firefive76
Kansas
Dumb question, but are you scanning a bunch of channels?
Bpd119
hello
ok the DOS screen seemed to rectify the situation. but i switched it to pre mdc and about half the mdc gets cut out before it sends it. its hard to explain but the mdc is not triggering at the base. u only hear half the squack sound. is there a way to make it send the MDC. im new to programming these but im learning along the way
Bpd119
also is there a way to make the side tone when you key the ptt when you have it on post mdc. thats why i changed it i like having the side tone when i know the mic has been pressed.
