Help with Kenwood DMR
racingfan360
Hey all, looking for someone who may be able to help. I'm trying to diagnose what looks like a compatibility issue between running DMR on a Kenwood NX and a Moto DP3600. Anyone willing to run a run a few simple tests for me please if you have access to a Kenwood NX in DMR mode, it would need some settings updated via the kpg software and some captures to be made using DSD+ or similar. TIA
kd4efm
Florida
What are you looking for? Most common issue is DSDM and non-DSDM (check box) with a hotspot.
Please give more detail to your question.
TIA
racingfan360
Thanks for reaching out. Im struggling to get the Kenwood Enhanced Encryption to work directly with Moto EP. I have same keys and settings in both, but it's not working. No issues with encryption disabled.
cavmedic
Pottstown Pa
On the kenwood, make sure you have OVCM disabled along with over the air ailias turned off.
Your KID’s are in the same slot
Make sure the Motorola is set for enhanced encryption ( should have the key on the display) and the NX should have the ( EE) on the display as well.
I have no issues running kenwoods and Motorolas together using ARC4 on a IPSC system mixing XPR repeaters and the same radios on a Kairos DMR simulcast system as well.
tweiss3
Is it time for Coffee?
Ohio
These are the things that most hang people up. I have XPRs and NXs running together with EE/EP
kd4efm
Florida
Note, basic encryption on Kenwood is 15 bit, Moto is 16 bit. Must get / use Enhanced Encryption (ARC4) on Kenwood with Motorola Enhanced.
RRR
OFFLINE
USA
KW Enh. Enc may work Portable to portable, but they sure won't work on a Mototrbo system, that has "Advantedge" turned on.
