Stealther-TX
- Joined
- Dec 30, 2005
- Messages
- 3
Hopefully this is just something I’m overlooking but I’m having issues with the mic. The problems I’m having are:
1. Mic does not transmit when the transmit key is pressed. The keypad lights up red but no transmission is initiated.
2. The keypad on the mic is not functional UNLESS the transmit key is depressed. Then the buttons work but still no transmission is made.
3. Mic Keypad illumination is not working other than when the transmit key is pressed.
Is there a mic lockout that I could have initiated? I’ve checked the settings under Aux and no lockout is activated.
Thanks in advance for any help or insight you can provide!
