Help with list of Mahoning, Trumbull and Mercer counties to monitor
afboy796
I am missing transmissions on my sds100 per listening to broadcastify and was wondering if anyone from around the Trumbull Mahoning or Mercer counties would share with me a list they monitor for police fire etc (for example I cannot listen to Liberty Twp. police) ... my antenna isn't the issue... thanks in advance!
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Post your Sentinel export so someone can take a look at your programming:
In Sentinel. click on the drop-down File menu & select "Export to hpe file (Favorites list).
Select any and all Favorites lists then proceed with the export.
Save the file created to a location on your PC that you can get to.
Open Windows Explorer (called File Explorer on Windows 10)
Right click on your exported file & choose Compress to ZIP file. (On earlier versions, you may see, instead, an option for "Send To". When you select that, you'll see an option to send the file to a compressed (zipped) folder.)
Once you have exported & zipped the file, then you can attached the zipped file to a post.
Kaf602
Northfield Ohio
All local and Sheriffs Office in Trumbull County is encrypted.
Nasby
Ohio
You won’t hear Liberty Twp or very many other law enforcement agencies in Trumbull or Mahoning County as they are nearly all encrypted. The database is woefully outdated as almost all of the analog frequencies for law enforcement in the two counties have not been used for years.
n3obl
Ø
PA
Well if it woefully outdated maybe someone should make a submission with the information that needs updated?
jrl44430
There are 3 departments in Trumbull County in the clear. Brookfield, Hubbard and Niles are VHF analog clear. The county jail is analog clear but runs low power with a range of less than 3 miles. All Warren schools and buses are now voice inversion. The city trash switched back to VHF but is now voice inversion.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
I have to laugh that the city trash felt the need for voice inversion.
jrl44430
Would you submit an update? Seriously (and this isn't directed at you but everyone), if there are things not correct in the database, please submit updates.
The database is really outdated since MARCS took over. All the analog VHF frequencies are not used for police except for the departments I listed. The old analog Warren trunking system is not used either. I will list the trash.
mtindor
OH/WV DB Admin
I have deprecated the Warren Smartnet trunked system. I'll await a submission from you regarding the rest.
Thank you!
Nasby
Ohio
Maybe you can do submissions for Mahoning County too. It’s just as bad. If not, I will. Thx!
