Help with Motorola cap code
I need some help before my head explodes. Here is what I have. We currently have the Motorola minitor IV pager (fire pagers) with the cap code of 890. Following the charts I have figure out the freq for tone A is Group 5 reed 159 – 903.2 and tone b is group 4 reed 140 140 – 321.7. My problem is we have documentation from our radio supplier that the freq programmed is 525.6 and 1122.5 I don’t understand how this could be if I follow the chart it this would be tone a is group 4 reed 149 and group 6 190.
Other note looking at OC II table 1 where does group 6 and 10 – 11 in OC II table 2 come in to play?
01001101 01111001 00100000 01101000 01100101 01100001 01100100 00100000 01101000 01110101 01110010 01110100
Steve Chapman
DPapay
Morris County, N.J.
There is no standard anymore with capcodes, since most dispatch consoles are custom programmable. If your pager supplier seems reliable, I would go with that info.
talkpair
Clinton County, MO
If you suspect that one of the two examples is correct, then just listen to the tone sequence over the air.
In the first example, the sequence is a high tone followed by a low tone.
The second example is the opposite.
You might want to check the cap codes on other pagers for a pattern.
A radio shop should quickly be able to use a service monitor to signal the pager and verify if either one is correct.
talkpair
Clinton County, MO
I think I have it figured out now.........assuming the 525.6 is a typo, and should read 524.6.
The full cap code should read "U890" for this combination, and is Motorola Table 3 Extended Code Plan.
see: http://www.midians.com/pdf/tone_signaling.pdf
If you look in the chart under "Column U Row 8", you'll see the number 46.
Next, refer to the chart Motorola Quick Call 2 One Plus One:
the "4" in 46 refers to reed group "4"........the digit 9 from the cap code is 524.6 Hz
the "6" in 46 refers to reed group "6"........the digit 0 from the cap code is 1122.5 Hz
Yes after some more head banging I figured we were using either R890 or U890 they both match group 4 and group 6.
Other quick question someone mention a “service monitor to signal the pager and verify if either one is correct” is this something I can make or purchase? I ask because we are buying new fire pager (50 of them) and would like to test them with out going over our county freq. So I would need something that can send a tone to these pagers with in a few feet and no further.
Thanks for your help
Chappy
radiofan1
Cheaper to pay a radio shop for an hour of their time. Service monitors cost lots a $$$.
talkpair
Clinton County, MO
add K890 to the list as well......i didn't realize there were duplicates in the same row.
If the shop is local...have them build you one pager and test it with your dispatcher.
This will verify the frequency and tones are correct.
Then, go ahead with the other 49.
Used service monitors are still in the thousands.....Either pay a shop, or turn all 50 new pagers on and have dispatch send you a test page......or wait for an actual call....this might give you the chance to test the batteries as well.
yea that the problem is each pager has 2 cap codes. One for group call and one individual cap code from 850 to 899. so I was hope to find a easier way to test, but I guess we will work with the local radio store.
Thanks for all your help.
DPapay
Morris County, N.J.
There are alot of mobiles and portables out there that are capable of doing two-tone encode. You may even have one in your inventory. If you were to have one set up, you could remove the antenna, and do all the testing you want.
firefive76
Kansas
Uh....DO NOT follow this advise unless you want to destroy your radio.
GTR8000
NY/NJ Database Guy
BEE00
Bad advice
Did you seriously just recommend transmitting without an antenna? :roll:
happychappy
I was thinking we have a zetron ?sp? encoder we use to page out. If put a smaller antenna on it and put it inside a metal box would that work?
thanks
Chappy
NCFire11
Or you could get a Dummy Load to slap on there..Transmission is limited to like 10 feet then. Metal boxes do not to much to transmission.
What i do to test our pagers is this. I take any portable radio and have a dummy load to fit it. I have my iPod Mp3 player with tones of our department on it as an audio file. (I use Audacity and save the tones you make as a .wav file.) I take a 3.5mm Male to male adapter and use a 3.5mm to 2.5mm reducer to plug into the mic port of the portable, and the other end plugs into the iPod. I key up the portalble and play tones as much as my heart desires.
