help with my wilson 1000
monitorboy
bay city ,midland,saginaw,mi.
i removed the coil housing and whip from the mag mount.is there supposed to continuity between the female threads and the center pin ...my meter beeps when i check them . i thought there wasnt to be any so maybe there is moisture inside the coil housing..................thanks in advance
movinon
Oklahoma
On mine the coax shorted where it enters the magmount. Pretty common. Cut the coax remove the cover on the magnet renew the connection to the mount.
Sent from my SAMSUNG-SM-G935A using Tapatalk
kf4eyr
plant city florida
yes there will be continuity between the center pin and the threads,,, it is a loaded coil,,,73 midnight special kf4eyr
jquittum
Yes, it's normal to show a DC short between the pin and threads.
