Ok, once you get your grounding set up, here are some suggestions:
Without having lots of trees around, I would suggest erecting a vertical antenna system. Put one up for one band (try 40 Meters). Make it a unipole and use an extensive radial system. How extensive? Well, broadcast stations routinely use over 100 radials. Ideally, these radials will be 1/4 wave each, but that's not etched in stone. If you lay them flat and secure them at the ends, you may get grass to grow around them so that they don't show.
Now, about that unipole, I suggested it because you are concerned about lightning. A bonus is that this antenna is DC grounded, so if it is struck by lightning, it will dissipate a significant portion of the charge before it ever gets to your radio. The Balun will help to isolate it from your shack further.
This sort of antenna system is also decoupled from your house with all of its RF noise. You can mount it well away from your home, and perhaps even disguise it as a flag pole. If you build it for 40 meters and play it carefully, you may be able to get it to load on 15 meters as well. Another point: most antenna tuners are more efficient when matching higher impedance to 50 0hm coax than lower impedance.
Good Luck!
Good Luck!
