Help with Oktibbeha CO.
tmkornegay
starkville ms.
I'm having trouble finding county s.o. and can,t find no trunking channels. Can some one pleaese help. The ones listed on this site are not it. I have a pro-163
INDY72
Indianapolis, IN
As of just an month ago the listing for the OK Co/MSU EDACS TRS were correct.
INDY72
Indianapolis, IN
Be sure to program it in properly. EDACS with first known LCN in chan 01 of the bank you are going to use. Mode for bank EDACS, as well as each freq. Do not use attenuation. Again start in CH 01 not 00. :) Which site are you trying to use? On the MSU site, there are a few freqs we didn't get the LCN' nailed down on.. If they have switched the CC to one of those then you may have to check its LCN nd add to correct slot accordingly. If this has occurred, please submit the new info and we will update the db.:D
tmkornegay
starkville ms.
I am using the MSU site and will get back with you on the LCNs. Im starting to wounder if they got some block or trying to block cause I can pick up on a signal and then nothing but buzzing. I even took the scanner with me and sat 50 ft from the tower and still cannot get it to stop.
Thanks For All Your Help
