help with pll receiver
kc9cra
Evansville, IN
I just got a pll receiver for Christmas. It has a button for ssb, but apparently, you have to hold it down to hear ssb transmissions. Is there a way to make it stick? If there isn't, is there a way to replace the button with a switch?
OCO
Central Michigan
If it's the same as the Kaito KA1102, here's a review, which also discusses SSB mode - note you must be in "page 9" to activate the BFO..
Have fun!
Merry Christmas..
kc9cra
Evansville, IN
Thanks everybody. The problem has been solved. I was apparently using the wrong buton to change pages all along. Something to know though. YOu can use the ssb function in other pages, but you are limited to 5khz steps, and you have to hold the button down in order to hear the ssb signal. The ssb switch is a toggle button located on the side of the unit just above the music/news switch.
