help with pro-106
scannerdaddy
Northfield Center, Ohio
just picked up rs pro-106. could not resist sale price. here is my problem(s). radio was cloned to the store display unit. it has all the local systems in one v-folder. example: MARCS, summit cty. 800 system and most summit county systems that are not on the regional trunked system, along with most of the local cities that are still analog. i want to move them into seperate v-folders so i can toggle on and off as needed. i am using the local library computer for now as my tower is being fixed by "geek squad". my daughter does not want to put software on her computer(win500) so i can not program this way. i bought the programming cable at the same time. i am in northfield center and would offer to pay a small fee if someone can help. i visit the library every day to check e=mail. p.m. me or contact at umpire255@netscape.net. i would exchange phone info this way too. thanks in advance.
Justin2595
Cuyahoga Falls, Ohio
You want them in different V-Folders? Or just Scan Lists? I am in Cuyahoga Falls by the way. I also have a PRO-106.
Cobra_Commander
InvisibleIndividual
Aurora,Ohio
Hi would you be able to help me program my 106 as well for summit county i tried programming it and when ever i let it scan through the bank with the summit county merc system it never trunk tracks or stops on the system at all i am so confused with this scanner on how to program it the correct way so it will trunk track the system correctly!
Justin2595
I could clone my scanner to your scanner. It has every county that touches summit county programed into it. Unless you have a computer that I could use to get a free trial version of the software, then I could do it that way (I have already used up all of my trail versions for the 106)
