Thank you. The R30 can do a duplex scan so if desired it can listen to the input frequency as well. I’m going to use the scanner 99% for military air and federal P25 but I am putting my County and the neighboring county in as well.
Mike
Sounds good!
I'm used to using Icom's software for the R30 although I do have RT's as well.
Icom just uses a box to enter your freq offset and then a + or - selection if you want to do duplex scanning.
RT's method is actually easier if you know the true TX frequency otherwise you must calculate it for Icom's software.
RT probably keeps it like that with their primary focus being amateur transceivers.
I've never really had the need for watching the inputs so I don't use the feature very often. Maybe when monitoring the local 2 meter repeaters but that would be about it.
