Help with programming BCD396T
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you're handy you can build the off center fed dipole - make the elements nice and wide in diameter and it will be more broad banded, and it's unobtrusive to boot. The article is here...
Homebrewed Off-Center Fed Dipole - The RadioReference Wiki
Not to add another wrinkle here, but it's entirely possible that the system is low power, and/or using directional antennas to concentrate coverage inside the base. Bottom line, if either or both are true, it's going to be very difficult to hear more than a mile or two away.
Mike
ffemt613
Oak Harbor, WA
Thanks Mike, Ill definitely look into that.
On the same token, im ordering a usb cable for it, and a sma to bnc adapter. that should hopefully help the problem a bit
