Help with programming cable
ham2020
Can anyone help
I want to make a cable to program the Motorola DP4600
The problem is that the company's cable is inside the chip EEPROM function when we install the programming cable to the device tells the device that there is a programming cable connected to it
I want to use ARDUINO to do this function
Can anyone help me read the code from my EEPROM and send it to me to use it in Arduino?
jaspence
Michigan
It is unlikely the code is written in a format or programming language that can be used in the Arduino. With Motorola, it is almost guaranteed that any code/software cannot be used without the approval of big M, which usually requires a financial investment.
ham2020
I don't mean to write code through the Arduino but I want to make a cable for the Motorola DP4600 programming
jonwienke
More Info Coming Soon!
VA
It doesn't matter. Even if you make a cable that successfully communicates with the radio (unlikely), you still have to buy the Motorola software, which is expensive.
ham2020
I just want to make a cable either the program will use CPS
n3obl
Ø
PA
The oem cable is not terrible at 80 dollars US new. I would rather use that then hack up a maybe connection.
Cheaper option is to get a rear accy connector with pins and make a usb rear cable. Just wire up the four usb wires to correct pins and you can read and write to radio though the back.
