Help with programming GM340
kkomarica
EU
Hi guys, I new to this part of RR and to Motorola radios and CPS. I'm hoping for a quick explanation of few things in the CPS.
Can someone please explain the "Rx Audio" options under Misc. tab. I have flat and filtered / squelched and unsquelched. What option should I use for simplex (PL/DPL squelch on some) and repeater work?
What is the difference between the options, a their usage?
The other question is "low level expansion" when talking to non motorola radios? yes or no?
Thanks for your help!
cmdrwill
So Cali
Those settings are most likely settings for the Accessory connector pins.
"low level expansion" Is a way that the radio adds sort of like boost, compression, to the transmitted audio to help off set the narrow band range problem.
