Hi everyone, i am having some problems with my
Realtek RTL2832U Elonics E4000 SDR Radio 64 - 1700 MHz bought from digitalhome88 in China.
When I stick it for the first time in my PC it fire up the Found New Hardware Wizard,
if I go next to install the soft automatically it does not find any driver and it does it twice.
In my Device Manager I get under Other devices 2 instance of Bulk-In, Interface.
After installing HDSDR on my laptop then I run ExtIO_USRP+FCD+RTL2832 + BorIP-1.2 BETA10_Setup and has specified I did point it to HDSDR directory, when it prompt me to Zadig I get in the scroll box and see 2 instance of Bulk-In,Interface (0) and (1). I use (0) and install WInUSB driver and then close Zadig after successful install.
In Device Manager under libusb WinUSB devices I have a Bulk-In,Interface with Yellow ! and another one with (Interface 0)
Then I fireup HDSDR and in the ExtIO I put RTL in device Hint.
THen F2 on HDSDR and i have some noise at 3658 on the 80meter band moving to FM station
like CKOI 96.9 at 300kwatt i dont even have signal, white noise is about -85 move to 104.1 with is 10 miles from home I can barely ear some thing, I think is is bandwidth setup issue.
Tuning 162.55 weather i got a little bit of signal and heard something. I am using the Stick that came with it. Tomorrow with try an external antenna.
but what setup should I put for Bandwidth for FM 2m band and FM broadcast.
Another thing if i close HDSDR when I open it up i cant start it. Device control fail to open device.
I have to uninstall both instance of Bulk-In,Interface in device manager and start all over again with runing ExtIO_USRP+FCD+RTL2832 + BorIP-1.2 BETA10_Setup
Very strange.
So I anyone can help I would appreciate
73's
Daniel
VA2DG
