Greetings. I have gradually been working on a project to set up my own repeater for private/business use. I went through the process to get an FCC business class license with a VHF repeater pair as I wanted more coverage than simplex would provide. VHF was chosen over UHF after some testing showed VHF performed better. For the mast I'm using a 33 foot telescoping carbon fibre mast appropriately guyed. The current antenna is a tram VHF antenna mounted about 30 feet up. I understand this is far from ideal height, however this is the best I can do currently. Terrain is fairly flat, environment is mostly suburban. LMR-400 coax throughout the system. Repeater is a Tait TB8100 purchased from a reliable vendor who tuned and programmed it for me. The duplexer is a VHF duplexer from Bridgecom, tuned by them for my frequency pair. Prior to receiving the Tait repeater I had done some testing with a Single Frequency Repeater on DMR, same antenna and coax, and this yielded decent results. Coverage range was easily 10 miles in most directions, minus one area where terrain is an issue. After receiving my Tait analog repeater and connecting the new Bridgecom duplexer, coverage is very poor. Approximately 3-4 miles in all directions before the signal begins to cut in and out. Due to this cutting in and out effect I suspect a duplexer issue. I understand the flatpack/mobile-type duplexers are meh at best for most applications and I'm considering switching to a more proper Sinclair 4-cavity duplexer. I'm also considering switching the antenna to something more substantial. I realize an increase in height would also help but as stated this isn't really an option at the moment. Any help from those with more experience is very greatly appreciated. I realize this system is far from commercial grade, nor does it need to be, I'm just looking to improve the system and get the best performance possible given the limitations. Thanks in advance,
Chris
Chris
