BCD325P2/BCD996P2: Help with RR DATA & 9962 with Proscan
KG5KS
Arkansas
Proscan is setup and working with 9962. Downloaded the csv file from RR, however the software wants to see a txt file. Any help is appreciated.
Thank you
KT
hiegtx
Dallas, TX
Thank you
KT
You selected getting a *.csv file for one or more counties?
The programming files for ProScan are *.txt. You can open that CSV file, then copy & paste into a ProScan programming file. ProScan also allows you to copy & paste from a web page.
But, since you are a Premium Subscriber, why not just use the RadioReference Import process to get exactly what you want into a programming file that can be used on your 996P2?
I see you indicate Arkansas in your profile. Which county (or agency, city, ??) that you are trying to set up?
KG5KS
Arkansas
Doesn't import as it says a database must be open when using " import "
Thank you
KT
KG5KS
Arkansas
Thank you
KT
Found it, now to add items both conventional and trunking. Appreciate your time
TNX again
KT
