yeah that's it.
Thanks for the help. I will be returning the scanner I purchased. Thank goodness I got it off e-bay at a good price! And will look into those scanners. Are they all around the same price range or is radioshack more expensive?
Radio Shack has been running the Pro-106/-197 "on sale", off & on, a little cheaper than what a dealer like ScannerMaster charges for the GRE equivalents.
But compare the two-
Here's the
Pro-106. Currently showing "on sale" @ $379.99 ($20.00 off the stated $399.99 list). It has been as cheap as $349.99 a month or two ago.
And the
PSR-500, at ScannerMaster. Currently $448.00. Here's a different dealer @
$409.95. There may be others even cheaper.
If you get the PSR-500, the only thing you'll need to buy is some batteries. It will run on 4 AA batteries, alkaline or rechargeables (I use rechargeables, with an external charger). It comes with an ac adapter & the pc cable.
If you get the Pro-106, besides the batteries, you'll also need to get the pc cable, if you want to program the scanner with software (highly recommended), and also an ac adapter. Now, Radio Shack is discontinuing their cable, based on this
thread. But if you can still find one, that'll set you back about $30 + tax. If not, you'd have to order the GRE cable (same thing, other than color), either from GRE
direct, or from a dealer like ScannerMaster. Depending on who, & where you buy it from, etc, $30-40 plus tax & shipping.
Figure another $25-30 for an ac adapter, and now you've spent at least $60 over the cost of the scanner to add the additional items you'll need.
So, while the Pro-106 "looks" cheaper, unless it's a
lot cheaper (more than just $20 off, maybe also with one of the infrequent "20% off Friends & Family coupons"), the PSR-500 may be the better "buy". Of course, if you can find a deal on a good used one, either model, with all the accessories included, then that would be even better.
