to listen to talkgroup, do you need a special scanner? One one I have, will that do it? How can you set up the scanner to listen to talkgroup? Let me know. Thanks
When I listen to EMS, I used the Bell FleetNet freq. You are saying if I buy a trunktracker scanner and I program the CACC freq. into the scanner the jumping around , so to say will stop.
Yes: Provided you program in the tower you can hear properly with the base frequency's and offsets.
All of this info for the 246 is in the sticky at the top of the forum and the wiki has all kinds of info as well.
Talking about base freq. and offsets.
____________________________
Custom Frequency Table
Base Spacing Offset
141.0150 15.0 380
151.7300 15.0 579
154.3200 15.0 632
System ID List
System ID Connect Tone
8230 Unknown
The text between the line, what is that? (and what is the spacing and offsets?) Can you give me a link that will explain to me the RR Custom Freq. Table please.
So is the software an essential or it just make your life easier.
You keep refering to «sticky» what are they and where are they?
Just put the control channels into the same site. The scanner will lock onto the first one it finds.
Yes Mike I know, but following your step by step instructions, how do you put multiple sites into the same system
