SDR# Help with sdr# setup
Saint
Fort Erie Ontario Canada
I have downloaded this version of sds# v.1.0.0. 1732 I have it set in the program as rtl-sdr (usb), it has all to plugins also, I set it up with my dongle and I went to the FM band and it works great picking up the FM stations. But when I change to AM to pick up the aircraft in the aircraft band I get nothing even when I sit on a ATIS frequency, I can hear it perfect on my other scanner but nothing on sds# it is set to AM, also having problems with the other bands picking up signals, any help appreciated
Steve
cas08832
have you repaired your sdr to receive aircraft signals? i ran into same problem. what kind of antenna are you using?
