Tytera Help With Users TYT UV-380
w5hex
installed into my new radio. I have a TYT MD-UV380. I downloaded a cvs file with all the USA and Canada users. The file is about 4.6M or so. I go to Read/Write then import the CVS file off the desktop. Plug in the data cable tell it to import the file, then write to radio. It takes 5 min or so to write to the radio. Then i go into the menu, utilities, radio settings, contacts csv, turn on. But when a USA user is transmitting I get ID Unknown. The file doesn't seem to be really installing. What am I doing wrong? I need some help.
frenchfry
The downloaded file has more than 120,000 contacts. You have to clean the file to have less than 120,000 contacts. I just sorted by country and took a lot of non-engish speaking countries out.
w2xq
Burlington County, NJ
You may want to grab the latest version of the N0GSG DMR Contact Manager Support Page that fetches the correct ID database (one source was broken, missing records). The software has filtering and selection within to control the number of entries to be put into the UV-380. HTH a bit.
