help with voice channels
bailly2
running sdrsharp and dsdplus. decodes control channels just fine. with voice channels all i hear on the recorded wav file is blips and beeps. was listening to a strong signal, same results on many frequencies, even outside with the gain up all the way or at 30. got the soundcard levels at a medium level. help.
M105
What type system are you listening to? Is it encrypted?
bailly2
No not encrypted. If it helps i found the freq not on what its listed as but 0.027mhz higher
M105
Is audio filter turned off in SDRSharp? Is frequency calibration (PPM) setting correct? Also note that it takes a decent computer to process the audio. If you are running an old junker it will act as you describe.
bailly2
audio filter is unchecked,,,frequency calibration is 0, dont know what it should be if i found the frequency 0.025 mhz higher,,,,brand new computer. 6 gigs of ram
bailly2
monitoring a nexedge control channel that is really close. getting a 15 for the signal strength in sdrsharp. can pick it up with close call in uniden scanner. why is dsdplus saying ERR22, ERR34?
bailly2
Sync:+NXDN48 TB CCDATA ERR26
Sync:+NXDN48 TB CCDATA ERR32
Sync:+NXDN48 TB CCDATA ERR28
Sync:+NXDN48 TB CCDATA ERR33
Sync:+NXDN48 TB CCDATA ERR31
Sync:-NXDN48 CB VOICE e:6r6r5r7m
Sync:+NXDN48 TB CCDATA ERR29
Sync:+NXDN48 TB CCDATA ERR30
Sync:+NXDN48 TB CCDATA ERR34
Sync:+NXDN48 TB CCDATA ERR35
Sync:+NXDN48 TB CCDATA ERR18
Sync:+NXDN48 TB CCDATA ERR27
Sync:+NXDN48 TB CCDATA ERR4
Sync:+NXDN48 TB CCDATA ERR25
Sync: no sync
bailly2
00:00:00,000 --> 00:00:01,000
2017/08/05 17:39:52
+nxdn48 tb voice
2
00:00:01,000 --> 00:00:02,000
2017/08/05 17:39:53
+nxdn48 tb voice
3
00:00:02,000 --> 00:00:03,000
2017/08/05 17:42:04
+nxdn48 tb voice
4
00:00:03,000 --> 00:00:04,000
2017/08/05 17:42:06
+nxdn48 tb voice
5
00:00:04,000 --> 00:00:05,000
2017/08/05 17:43:22
+nxdn48 tb voice
6
00:00:05,000 --> 00:00:06,000
2017/08/05 17:45:15
+nxdn48 tb voice
7
00:00:06,000 --> 00:00:07,000
2017/08/05 17:50:10
+nxdn48 tb voice
8
00:00:07,000 --> 00:00:08,000
2017/08/05 17:51:00
+nxdn48 tb voice
9
00:00:08,000 --> 00:00:09,000
2017/08/05 17:51:01
+nxdn48 tb voice
10
00:00:09,000 --> 00:00:10,000
2017/08/05 17:53:40
+nxdn48 tb voice
00:00:10,000 --> 00:00:11,000
2017/08/05 17:53:45
+nxdn48 tb voice
12
00:00:11,000 --> 00:00:12,000
2017/08/05 17:58:27
+nxdn48 tb voice
13
00:00:12,000 --> 00:00:13,000
2017/08/05 18:00:50
+nxdn48 tb voice
14
00:00:13,000 --> 00:00:14,000
2017/08/05 18:00:51
+nxdn48 tb voice
15
00:00:14,000 --> 00:00:15,000
2017/08/05 18:00:55
+nxdn48 tb voice
16
00:00:15,000 --> 00:00:16,000
2017/08/05 18:00:59
+nxdn48 tb voice
17
00:00:16,000 --> 00:00:17,000
2017/08/05 18:01:00
+nxdn48 tb voice
18
00:00:17,000 --> 00:00:18,000
2017/08/05 18:01:01
+nxdn48 tb voice
19
00:00:18,000 --> 00:00:19,000
2017/08/05 18:05:41
+nxdn48 tb voice
20
00:00:19,000 --> 00:00:20,000
2017/08/05 18:05:43
+nxdn48 tb voice
21
00:00:20,000 --> 00:00:21,000
2017/08/05 18:05:50
+nxdn48 tb voice
22
00:00:21,000 --> 00:00:22,000
2017/08/05 18:16:05
+nxdn48 tb ccdata
slicerwizard
Toronto, Ontario
Show us the audio, not the bad decoding. Press that PrtSc key, paste the image into mspaint and save it as a PNG, then upload it here. Need to see the DSD+ source audio window and your SDR# settings.
bailly2
ok sent
bailly2
still garbled with the gain at 6 or 40
moonbounce
In the controller I would slide the RF Gain back a touch, too strong a gain can have the same results as low gain. I would also click on the RTL-AGC see if that does anything. I would also put a check in the "Snap to Grid" and "Correct IQ" boxes.
MB
slicerwizard
Toronto, Ontario
You appear to be just randomly sliding the audio gain in SDR#. In one image, you have it set low and DSD+ shows barely a blip of RX'd audio. Then in another image, you have the audio gain even lower, pretty much at zero.
Can't see what you have SDR#'s audio output device set to. I assume it's a virtual cable, but who knows, maybe you have it set to your speakers? I dunno...
Bandwidth is too wide, but not the source of your problems. 8 kHz would be better, assuming you have your PPM correction set properly.
Filter order of 1000 seems excessive although I don't recall seeing any guidance on that setting anywhere. IIRC, 100 has worked well enough for me the few times I've used SDR#.
bailly2
i have set the audio gain at 40, 50, 30, seems to be a little better at 30 but still garbled. audio output is set to cable out, dsdplus picks up what sdrsharp is receiving. ill try 8khz bandwidth. ill try filter order of 100
