Help with Whistler 1065
battchief57
Lawrenceville NJ
Anyone / Whistler 1065 to program a talk group how do you get to a dec hex. Is that how a new frequency is set?
hiegtx
Dallas, TX
The frequency is set in the TSYS object.
If your programming manually, rather than using software, see:
Programming Shortcut PSR-500/600 RS Pro-106/197 - The RadioReference Wiki
Also,
Easier to Read Pro-106/197/PSR500/600 Digital Scanner Manual
Getting Started with your GRE/RS Object Oriented Scanner - The RadioReference Wiki
While software is not required, it certainly makes things quicker and much more accurate, especially for a new user. That's because you can see most all of the required information, at one time, making it much easier to find any simple errors or omissions.
See Object Oriented Scanner Software - The RadioReference Wiki
While these pages refer to other scanners, your WS1065 uses the same programming methods and software as the other units listed, and is the follow-on model to the PSR-600. The three software packages listed, WIN500, PSREdit500, and ARC500, all have thirty day free trial periods. You can use the software for thirty days before you have to purchase or discontinue use. If you become a Premium Subscriber, you can use the software to down directly from this site to the software, speeding the progress of your programming, as well as enhancing accuracy. However, the software can be used to enter frequency & talkgroup information directly, without upgrading to Premium.
