As Lou stated, format the spreadsheet (excel in my case).
Code:
freq tag freq RX Mode PL/DPL Delay
1. Bedford Co 855.23750 EDACS 0.0
2. Obici 155.40000 PL 110.9 D
3. Obici 29.00000 PL 155.4
4. Obici 155.40000 PL 110.9
The above 4 samples were copied as follows:
1. Directly from a line on a Win92 file.
2. Directly from a line on a Win92 file then pasted into excel then formatted the freq to number with 4 decimal.
3. Same as in 2 but the freq was left to 155.4 in excel then copied and paste into Win92. Note, the unformatted freq did not paste.
4. Same as 1 but copied to excel first then copied to Win92 after reformatting the freq. Note, the absence of the D under delay in this instance.
One additional note on alpha tags...do not try to paste a tag which has more then 12 characters into either the freq tag or ID tag.
The ID number must meet the criteria for the type trunking system selected, and if EDACS or Mot type 1, must meet the AFS criteria if selected. In type IIi Mot, the correct fleetmqp must be set also.
