Help with XTS2500
xxkinetikxx
So I just found an XTS2500 sitting on the tailgate of my truck about a week ago and being the geek that I am I was curious to mess with it. I ordered a charger from ebay and just got it in today and was curious if I should be able to turn it on after about 15 mins of charging or if it would turn on in the charger or is it busted?
DPapay
Morris County, N.J.
If the battery is ok, then it should turn on in 15 min, do you have a volt meter to check the battery? If it is indeed ok, and the radio still wont turn on, then my guess it has been disabled by the system admin. Of course the radio could just be broken.
xxkinetikxx
No volt tester but after leaving it on the charger over night here is what happens when I turn it on.
The little led at the top of the radio flashes 1 time. and "SELF TEST" flashes on the screen 1 time then nothing.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Lets start by him posting the model #. That way we will know if it is 800 MHz or not and the possibility of it being inhibited.
I just took a count of my 800 radios and none are MIA so it's not one of mine..lol
WayneH
Forums Veteran
Super Moderator
Your master site
So I just found an XTS2500 sitting on the tailgate of my truck about a week ago...
I hope that you want to power it up so you can figure out whose it is so you can return it.....right? It does sound like it's possibly been inhibited as KS4VT suggests. If it has then the radio is useless to you and anyone but the owner and Motorola (as they can restore it). I would suggest turning it in to your local P.D. and letting them figure it out.
RKG
Boston, MA
Non-800, non-trunked radios can also be inhibited (by MDC command).
Josh
Auburn Hills, Michigan
Yep, self-test then nothing means inhibited.
The radio is in a dormant state with all buttons and TX/RX audio disabled. If on, it sits on the same channel/talkgroup/whatever until it is uninhibited.
Motorola won't fix it for you either. It seems apparent that the radio was reported missing and ID placed on the inhibit list as a precaution.
xxkinetikxx
Well then I guess I spent $40 on a charger to find out its not a real fun walkie talkie lol. Ok so your best guess would be PD?
Anyone need a spare charger?
N4DES
South FL
Yep that would be correct and being it is a radio worth more than $2,000 there must be some kind of property sticker on it. If there isn't PM the serial number to me if you want and I have contacts who can run it to find the original purchasing department/agency and you can return it.
N4DES
South FL
I never said it couldn't. But being 800 there is a much better chance as there aren't too many agencies, at least around here, that even know what MDC even is.
