help with XTS3000 programming
f1shs
Hi folks !
I would lije to know with witch version of RSS / CPS my XTS3000 Mod 3 could be programmed .
Model H09RDH9PW7BN
Host R07.09.02 - DSPN 08.02.04
Flashcode 500008-000000-1
I've a RIB and a cable for programming both MTS2000 and XTS3000.
The radio could be read with a RSS 9.05.00 but "the software in radio is too new" as i could see ...
I've tried with CPS, but no connexion is possible.
Could you help me to know the right version of CPS or RSS ?
Thank's
Pierre
F1SHS
grem467
Houston, TX
You need to call motorola and obtain the current version of CPS, which is 5.00.02. The rib and cable you mentioned will work just fine.
