Help with XTS5000 Programming
jsimpson007
I am receiving this error. On the right is my radio (which I can read) and on the left is the codeplug that I want to upload to the radio on the right. When I try and upload the codeplug on the left to my radio I receive this error. I have tried to copying method but when I drag it wont copy. Appreciate everyones help here!
N1GAW
This should really be in the Motorola forum as it is not a general scanner question. You will get better answers there. Just click on the report button and ask for it to be moved for you.
marcotor
I ♥ÆS Ø
Sunny SoCal
Try again with drag and drop. Won't ever directly write to a radio the serial does not match. Clone is likely out, if the flash is different. Click on the Tree icon, and hold. Give it a little movement to the right you should see a little box icon under the arrow. Drop it on the tree icon on the right instance, and it should copy over. Let us know if it works :)
jsimpson007
Hey it's not working. I appreciate everyone's help with this. Any other options?
merlin
South East Idaho
Your new codeplug was not created with your radio serial/model number.
Very first step creating new codeplugs is entering the serial number for the specific radio it will go into.
You can drag and drop the rest of the personality either way as long as the destination codeplug is not key locked.
That key lock is optional but once set, it makes it read only without the key.
The radio SN is that line at the top of the tree. The codeplug will only program into that specific radio.
73s
n3obl
Ø
PA
73s
You cant just enter a serial number? He needs to do a top level drag and drop vs cloning.
APX7500X2
NY/CT
73s
Your signature sure covers that post LMAO
merlin
South East Idaho
I never could get drag and drop to work, I resort to copy/paste.
Open Depot > select tools > scroll down to "create new codeplug" a window pops up,
so what is the first entry ?
That is how I start skeleton codeplugs. Only need one for each radio.
I have a good hundred codeplugs, not a one of them will program into my radio, Error "wrong serial number"
Good for reference though.
William2910
Land of entrapment
One issue I always had with drag and drop in cps is the scan lists never fully drag and dropped over. Everything else did, or maybe it was the clone radio feature that did this. I know it was one but would have to manually set the scan lists into the other radio. It was very odd.
