Help
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Ask this in the Ohio forum. Be sure to state the scanner and software you are using so folks can give you the proper answers
73 Mike
WayneH
Forums Veteran
Super Moderator
Your master site
Moved to the Ohio forum. wdavey, please take a moment to look over ALL forums and read stickied posts (at the top of forums) instructing you what to post where. Thanks.
steveh552
Canal Winchester Ohio
If you have the pro 96, you could go to PGM Then Func. then PGM, number 2 then number 7 and enter. that will load vscanner 7 which has Ohio Marcs in it. To narrow to just the patrol post and not everything else on MARCS, use Func 5 which closes the bank so it only uses stored talkgroups.
