Help
judyjack
nova scotia
I recently downloaded win 500 to my psr 600 and i web imported from radio reference trucked systema and conventional frequencies, now i am lost, my scanner will not scan and it says nothing enabled!. Can someone help me....
thanks in advance
kennyloatman
Cumberland Co., NJ
Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 2_2_1 like Mac OS X; en-us) AppleWebKit/525.18.1 (KHTML, like Gecko) Version/3.1.1 Mobile/5H11 Safari/525.20)
thanks in advance
Do you have the systems locked out? Go into the menu (if it is like a uniden) and find the lock/unlock systems.
gd9704
Lake County, Ohio
My PSR-500 had me flummoxed with the exact same problem......
The key here is to not freak out (like I did a year ago) and calmly figure out what's wrong.....
I think you simply need to enable at least one scan list. (Push the "1" button, or whatever scanlist you've loaded your talkgroups/frequencies on.)
I'm sure those with much more knowlege than I will get you straightened out, but stay calm........
qlajlu
Silent Key
Kearns, Utah
When you turn your scanner on you should get the "Welcome Screen," then you should see the following screen:
When you uploaded the objects to the scanner, they were placed in scan list #1 by default. If you are not seeing that number, press the #1 key on the key pad. That should put the scan list in active memory (you might have to press "Scan" again, also).
Welcome to RR.com. Let us know if you have continuing problems by posting back in this thread.
