help
DaveIN
Founders Curmudgen
West Michigan
You should make sure that the included cable is in the box that came with the radio. It's a serial port connection on one end and a mini connector on the other, that connects to the front of the radio. If you intend to use it with a USB to serial converter, you'll need to make sure the latest drivers are installed.
