Help
budman8
Columbus,Ohio
I have just purchased a bc796 and I live in columbus and use the motorola 2 here.My question is I would like to listen to the icall and have it turned on.Do I need to do anything else because I am not hearing them.Would appreciate anyones help.I also have the arc250 software so if anyone has those freqs list would appreciate that also.Thank You !
I Guess I should say I live in columbus,Ohio. :lol:
RFfreeTLD
NW Ohio
Make sure you have the scanner set to ID SEARCH mode for the trunking system. The FCCA public safety system has plenty of I-Calls, you may even be overwhelmed. Ohio MARCS will also yield I-Calls on occasion.
I have found that the BC796 coupled with the program ID Tracker makes a very powerful tool. (http://bellsouthpwp.net/k/d/kd5eis/IDTracker/IDTracker.htm) You can easily manage many more IDs including I-Call IDs and set ranges up to hear only the I-Calls you want to listen to.
Rob F
budman8
Columbus,Ohio
Thank You
That is a great program.Wish I new about this one before I got the other.I see i-calls now how do I Identify them. Can I also program them into my scan also.Thank you for your help. Here is some of what I have on my list.
762557-icall
750200-icall
750730-icall
