HELP
silverwolf45331
have a new scanner ws1040 have no clue on how to programm it using programming cable and a computer. my old one you just programmed it by hand
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The links (always in blue) in the article below will give you everything you need to know to get started...
Getting Started with your GRE/RS Object Oriented Scanner - The RadioReference Wiki
Keep in mind that a WS1040 is really a repackaged PSR-500 from GRE; therefore most anything written for the 500 is going to work. There is a link in the above article for manual programming, and at the bottom, is the link for the Easier to Read manual
It would be most helpful if we knew where you are (county/state is fine), and precisely what you are trying to hear. This way, folks from your neck of the woods can help Mike
silverwolf45331
thanks i am i darke county ohio would like to know how to use pc/if cable to program. I have no idea where to even start like i said my last one i programmed manually.
