Henry Co Ga PD Codes &/or Signals
BFNITY
Southeastern USA
Please forgive me if this question has already been addressed but, if it has, I was unable to locate info related thereto.
Does anybody have or know where to find the radio Signals &/or Codes for the Henry County, Georgia POLICE Dep't?
I've searched through the major serach engines & have not been able to find ANYTHING, as related to the Police Dep't... Sheriff, I found.
One might presume that the SO's Codes are the same as the PD but, I'm unable to solidly confirm that.
Thanks, in advance!
BFNiTY,
Atlanta, Ga
Metrofire31
Auburn-Opelika, AL
Henry County PD/SO
Unless something has changed that I'm unaware of, even if you discover the codes, you won't get an opportunity to use them because HCPD/HCSO both operate on an encrypted EDACS trucked system. I believe about the only thing you can monitor on that system are HCFD Dispatch only and the always exciting garbage collection and water department..
GA184
Henry / Fayette counties
Henry County FD & PD
Henry County has a very unique system. The system is EDACS - PROVOICE, DIGITAL and I can confirm that because when you go through the frequencies manually, you hear what sounds like a robot transmission. However if you have a digital scanner, you can hear the HCFD dispatch and all Tac channels. If your really into hearing Henry County and you have the patience, you can actually hear the fire dept and the police dept. on a regular 800mhz, trunk tracking scanner. The thing is, you can not hear them all the time and you can NOT hear the units at all, just the dispatcher. The only thing I can figure is that this is a glitch or the dispatcher doesnt have the encryption turned on.
tncem
Stockbridge, GA
Hey CSHIFTLT
What type scanner (make/model) are you using?
Better yet, please contact me at tncem@yahoo.com. I am new to the area and about to move into Henry County.
CSHIFTLT
Henry
If you are going to listen to Henry co. edacs, using pro 95, you will only hear analog groups as documented in earlier post, you will not hear provoice digital.
tncem
Stockbridge, GA
I have a Uniden 396T...digital/analog
Am I still out of luck as I don't see any references to Henry County PD at all?
CSHIFTLT
Henry
Henry Co. is not encrypted,(just Provoice/digital) the codes/signals pretty much same as GSP(unless you have a Provoice radio you will not hear these) Henry Fire is analog only in alert/Dispatch of call, then returns to Provoice.
hope this helps
GEORGIA STATE PATROL 10-SIGNALS:
10-0 Caution 10-56 Intoxicated Pedestrian
10-1 Unable To Copy Change Location 10-57 Hit & Run(F,PI,PD)
10-2 Signal Good 10-58 Direct Traffic
10-3 Stop Transmitting 10-59 Convoy Or Escort
10-4 Acknowledgement 10-60 ___Will Leave This Station
10-5 Relay 10-61 FBI Signal In Following Cars
10-6 Busy, Unless Urgent 10-62 Reply To Message
10-7 Out Of Service 10-63 Prepare To Make Written Copy
10-8 In Service 10-65 Mechanical Breakdown
10-9 Repeat 10-68 Dispatch Information
10-10 Fight Or Disorder Reported 10-69 Message Received
10-11 Dog Case 10-70 Fire
10-12 Stand By (stop) 10-74 Negative
10-13 Weather/Road Report 10-75 In Contact With____
10-14 Prowler Report 10-76 Enroute
10-15 Burglary 10-77 Estimated Time Of Arrival
10-16 Domestic Problem 10-78 Need Assistance
10-17 Armed Robbery 10-79 Notify Coroner
10-18 Quickly 10-80 Chase In Progress
10-19 Return To_____ 10-81 Give Location & Status
10-20 Location 10-82 Reserve Lodging
10-21 Call By Phone 10-83 Working School Crossing
10-22 Disregard 10-84 Special Detail
10-23 Arrived At Scene 10-85 Delayed Due To_____
10-24 Completed Last Assignment 10-86 Officer/Operator On Duty
10-25 Report In Person (meet) 10-87 Pick Up/Distribute Checks
10-26 Detaining Subject, Expedite 10-88 Present Telephone Number
10-27 Driver's License Information 10-89 Bomb Threat
10-28 Vehicle Registration Info. 10-90 Bank Threat
10-29 Check Stolen/Wanted 10-91 Pick Up Prisoner/Subject
10-30 Unnecessary Use Of Radio 10-92 Improperly Park Vehicle
10-31 Crime In Progress 10-93 Blockade
10-32 Subject With Firearms 10-94 Drag Racing
10-33 Emergency 10-95 Prisoner/Subject In Custody
10-34 Riot 10-96 Mental Subject
10-35 Transportation Liquor 10-97 Check Signal
10-36 Correct Time 10-98 Prison/Jail Break
10-37 Investigate Suspicious 10-99 Wanted/Stolen Indicated
Person/Vehicle 10-101 Medical Acknowledgement
10-38 Stopping Suspicious 10-102 Send Rescue Units To____
Person/Vehicle 10-103 Send Police Units To____
10-39 Resume Normal Operations 10-104 Unable To Locate
10-40 If Not Stolen, Check W/Owner 10-105 Patient Refuses Service
10-41 Beginning Four Of Duty 10-106 Patient Refuses Treatment
10-42 Ending Tour Of Duty 10-107 Patient Pickup By Other Means
10-43 Murder Reported 10-108 Transfer Patient From__To__
10-44 Suicide Or Attempt 10-109 Patient Condition Codes:
10-45 Hold Evidence, GBI Enroute A. Walking But Injured
10-46 Assist Motorist B. Moderate Injury
10-47 Emergency Road Repair C. Severely Injured
10-48 Traffic Light Out D. Dead
10-49 Speeding Auto 10-110 Multi-Injury Accident
10-50 Accident (F, PI, PD)
10-51 Wrecker Needed
10-52 Ambulance Needed
10-53 Road Blocked At____
10-54 Livestocked/Carcass On Road
10-55 Intoxicated Driver
