I will program in tonight see if i hear anything and catch sysid for you.I understand some testing is underway with the new Henry county P25 system.
Does anyone have the System ID for this? If not, how can I obtain it without being there to snag it OTA?
Thank you in advance
Hey that would be great!I will program in tonight see if i hear anything and catch sysid for you.
Yep, FFF works for SYS ID (Sorry, I know I asked for Sys ID at first) but I need the WACN, nothing comes through, a signal won't even show up, with FFFF as WACN on a P25 trunking systemAre you using FFFF or FFFFF?
Ok but just to be clear are you entering a WACN of four F's or five F's? It needs to be five but you keep indicating four - just trying to make sure.Yep, FFF works for SYS ID (Sorry, I know I asked for Sys ID at first) but I need the WACN, nothing comes through, a signal won't even show up, with FFFF as WACN on a P25 trunking system
Absolutely sure, I have other systems in it and all pick up fine with the correct WACN, and I have been over this with a Unication tech, and I just need the WACN to see if I can catch anything on Henry co's new P25 system that is "supposed" to be in testing phases. Just wanted to comfirm this and see what I could hear.Ok but just to be clear are you entering a WACN of four F's or five F's? It needs to be five but you keep indicating four - just trying to make sure.
ok - I started questioning myself so to be sure, I just took a known system with a known WACN and SYSID, created a new copy of that system, changed the WACN to FFFFF and SYSID to FFF and it's working fine.Absolutely sure, I have other systems in it and all pick up fine with the correct WACN, and I have been over this with a Unication tech, and I just need the WACN to see if I can catch anything on Henry co's new P25 system that is "supposed" to be in testing phases. Just wanted to comfirm this and see what I could hear.
Ok....ok - I started questioning myself so to be sure, I just took a known system with a known WACN and SYSID, created a new copy of that system, changed the WACN to FFFFF and SYSID to FFF and it's working fine.
Curious - if you listen to the system frequencies as conventional channels, do you find one that appears to be a P25 control channel? It should be pretty obvious....So far they are still on edacs system I haven't heard any tgids using the frequencies programmed as p25 trunk instead of the edacs.
No sir, the Spalding county system does me no good for hearing Henry counties new P25 system.
