I understand some testing is underway with the new Henry county P25 system.
Does anyone have the System ID for this? If not, how can I obtain it without being there to snag it OTA?
Thank you in advance
I will program in tonight see if i hear anything and catch sysid for you.
Are you using FFFF or FFFFF?
Yep, FFF works for SYS ID (Sorry, I know I asked for Sys ID at first) but I need the WACN, nothing comes through, a signal won't even show up, with FFFF as WACN on a P25 trunking system
Ok but just to be clear are you entering a WACN of four F's or five F's? It needs to be five but you keep indicating four - just trying to make sure.
Absolutely sure, I have other systems in it and all pick up fine with the correct WACN, and I have been over this with a Unication tech, and I just need the WACN to see if I can catch anything on Henry co's new P25 system that is "supposed" to be in testing phases. Just wanted to comfirm this and see what I could hear.
ok - I started questioning myself so to be sure, I just took a known system with a known WACN and SYSID, created a new copy of that system, changed the WACN to FFFFF and SYSID to FFF and it's working fine.
So far they are still on edacs system I haven't heard any tgids using the frequencies programmed as p25 trunk instead of the edacs.
