I Programed all them channels into my bcd 996 p2 uniden scanner. Get no signal on bars and always displays NFM Please let me know why this is
I had a similar problem with both my HomePatrol II, and my BCD325P2.
There are some dead spots in town that prevent reception of the signal from the tower located on SR 281 over by Hamler, OH.
With my BCD325P2 I had to move it around my table until I found a location where the signal strength was the best and I started receiving transmissions for both County and City units.
With my HomePatrol II, I actually had to take the scanner mobile in my vehicle, drive out to the tower location and wait for a transmission to make sure it was actually programmed correctly and working properly - which it did. I then drove back towards town and watched the signal strength reduce from a 5 out of 5 to eventually a 0 out of 5 in some parts of town.
I've been advised to get a Remtronix antenna, which has been ordered and being shipped as of this date, and this should improve my reception so my HP-2 should work.
My suggestion to you is to drive out to the tower to make sure your scanner is properly programmed and working, then drive back home monitoring your signal strength to see if your area is an issue effecting your reception. Then take your scanner around the inside of your home and locate the areas with the best signal strength and set your scanner in the best location that works for you.
I will let you know if the Remtronix antenna resolves my issue, and if so, then you can decide if that is the direction you may want to take.
