I see that Henry County is planning on implementing a 700 MHz P25 TRS. Does anyone know if this new system will become part of the MARCS TRS?
73's
Ron
73's
Ron
Look for NWOPSRS and MARCS-IP, they are in the database.I am not picking up Henry or Wood County on my Home Patrol. Do I need to reprogram something? Totally clueless here... All help appreciated.
Anyone in the Henry County area get the Northwest Signal newspaper or subscribe to the online version. They had a story about a week and a half ago talking about the latest delay with this system and I was curious what was causing the this delay.
54806? I don't show this in the MARCS database. Did you submit it?The Henry County Ohio Sheriff Department, in Napoleon, Ohio, is NOT currently on the Northwest Ohio Regional Public Safety System with the primary control channel of 771.70625 and TGID of 10488. They will not be on that until later.
They ARE currently on Ohio MARCS-IP: Multi-Agency Radio Communications with the primary control channel of 773.30625, and the alternate control channel is 771.28125 with the TGID of 54806.
I live in Henry County and discovered this information by using the search mode on my BCD325P2
It is probably Napoleon PD, they are switched over to the Lucas Co system as is Napoleon Fire. The rest of the county is supposed to be switched over by the end of the month.Over the past few weeks have been receiving police dispatch traffic on TGID 13778 with Henry County (35XXXXX) Unit IDs. Haven’t been able to ID the department.
I believe that 16-10 is a Napoleon Fire Ops channel. They page on their main channel and have been switching to 16-10 when enroute. If you can hear their paging, which is also being simulcast on their VHF channel, the dispatcher will assign them an Ops channel when paging.I’ve probably been missing a ton of Henry County traffic because I’ve had my location settings fouled up in my SDS scanners. Now hearing dispatch traffic on Operations 16-10 (TGID 13688). Working to identify.
Update: Dispatcher is UID 3566005. Mobile UID 3566514 and 3566500.
I can confirm 13778 is Napoleon PD Dispatch. Submitting.It is probably Napoleon PD, they are switched over to the Lucas Co system as is Napoleon Fire. The rest of the county is supposed to be switched over by the end of the month.
