Unfortunately, without some idea of the receiver being used, it's difficult to make a good recommendation (I ran a scanner/swl net in the Baltimore area for almost a decade so I've seen this question before :wink: )
If your receiver can accept a 50/75 ohm coax input, here's an interesting suggestion that Tom Alleman of NASWA fame made many years ago, and I've used it to good effect; make 4 25 foot lengths of wire, connect 2 to the braid, 2 to the center conductor. Feed with a length of RG59U 75 ohm coax or similar (I've tried 50 ohm coax and it didn't work as well) . String the 4 lengths outward in a fan shape - voila, you have a small fan dipole. It's untuned (a small coax tuner might help, again depending on your receiver), and the fact that it's fed with coax will help keep the noise level down somewhat.
You can even tune this somewhat by making the 4 lengths resonant; 2 lengths would be resonant to the lowest band of interest, the other 2 the highest. You would simply use the famous 468/f(mhz) formula, then divide the resulting length in half to find out what the correct lengths would be for each leg. I did this using 4 and 16 mhz as my low and high points, and it worked pretty well. I did use a small MFJ tuner at the time.
Sadly the components for making tuners are getting harder and harder to find; there are numerous schematics in ham books, mags and such, but the parts are another matter. Tuners aren't all that expensive, tho, particularly for listening applications; for us hams, who can run lots of power, that becomes a little more of an issue.
73s Mike
