SpaceForceCmdr
I'm pulling the trigger on my first HF radio. My antenna situation will not be ideal, and I'm going to be limited to indoors. I've got about 30' of length in my attic, so I'm thinking I'll get a 20m dipole, and just focus on that band for now. Is there anything else I should consider? Would some sort of loop maybe be better?
Here's my situation: I've been SWL-ing with a wire running the length of my attic, and it works OK. Problem is, part of my attic is finished, so accessing the very peak of the roof's underside is tricky. I could take the easy route and run the wire across the unfinished section (see green line in photo)
But, as you can see, some of the insulation has metallic backing. I'm guessing this would block some of the signal, and I'm also not sure how close the dipole wire could be to it without posing a danger. Could it possibly arc? Most I'd be running is 100W. Also, in this configuration, the antenna would be directly over my shack/room. The ceiling is about 4' above my head, and then however thick the floor is, and then maybe another 5-6' to the antenna, so let's say the antenna would be about 9-10 feet above me. Using an RF calculator, it sounds like I'd be well beyond the min. safe distance.
OK, so now option #2. I could climb up to the "upper" attic and string the antenna from end to end right under the eave of the roof. There is insulation with metal backing up there, too, but the dipole would be over it. The downsides to this are there's also some electrical lines running up there, and there's some old knob and tube wiring which is supposed to be nonfunctional. The other downside is getting up there would be a real pain in the butt. I guess if my tx and rx would be a lot better, it'd be worth the trouble. Here's what it looks like, and the green line is where the antenna would be.
Really appreciate any insight/advice on this situation. Thanks!!
