I'm a broadcast feed provider for the VHF and 800Mhz SAFE-T system in Indiana using an ST-2 antennacraft scantenna mounted on top of my 2 story house on a mast secured to chimney. Works very very well.
Ok so now Since the advent of SDR and affordable rtl-sdr dongles and my awesome huge gaming laptop that I use for work programming CAD Catia V5 and 3D cutter paths for our laser cutting machine, I've delved into the 0-30Mhz band monitoring (would love to become a licensed HAM operator). And so I bought an end fed long wire antenna and have failed to get better reception than when I hook up to my ST-2 antenna. I ran the longwire through the inside peak of my attic and back down through a rear closet and hooked up to a coaxial cable hooked up to the box provided. Poor reception but maybe even more importantly is the huge amount of NOISE all across the bands. Whew. And getting up into the attic was no fun with the fiberglass insulation and low head room and taking careful steps across the framing of the ceiling. What am I doing wrong? Should I be getting like X times better reception with a long wire versus the low low noise and pretty darn good reception on that ST-2 antenna? Can anything be added to the ST-2 to improve HF reception? Are there vertical pole antennas that would work better mounting near the ST-2 antenna???
