Wirelessly posted (Mozilla/5.0 (iPod; CPU iPhone OS 5_1_1 like Mac OS X) AppleWebKit/534.46 (KHTML, like Gecko) Version/5.1 Mobile/9B206 Safari/7534.48.3)
Not sure if this is the correct forum to post in, but I thought this would be the most appropriate one. I was thinking if it would be possible to have an HF trunked system? I know that hams can have digital on HF, but I'm curious to know if public safety can use trunking on HF?
That is a multi part question.
Is it possible to have an HF trunking system? Technically yes, it is possible.
Can public safety use trunking on HF. Again, it would be technically possible, but public service is not, as a general rule, on HF.
There are no trunking systems on HF that I am aware of. Sure, you might look at some of the digital modes like ALE as having a “trunking” potential, but none are on HF that I know of that are like what you are thinking about (i.e. no traditional trunking systems as found in VHF and UHF FM and digital communications networks).
Trunking really does not have an application on HF for several reasons.
FM is very infrequently used on HF, particularly seldom below 25 MHz. AM and SSB modes are the norm for voice. Squelch does not work particularly well for SSB modes, so it would be hard to have a radio squelched between calls in the talkgroup.
The entire HF range of frequencies contains less bandwidth than the 148 to 178 MHz VHF-Hi band, and this narrow range is shared by many, many, users world wide (instead of just the 50 to 150 miles as would be the VHF-Hi band), so there are more limited regions to have multiple frequencies for selection for the talkgroup.
HF is affected by propagation much more than VHF or UHF. So it would not be uncommon for your link freq to be wiped out by distant stations, meaning your talkgroup could easily become broken.
T!
