Hello,
I would like to buy FT-450D and operate in HF
In my apartment (Germany) there is no ground connection, is it better skip HF project?
I was referring to the radio itself not to antennaVery few antennas need a connection to ground to operate effectively. A dipole, center fed, offset fed or complex like the G5RV or ZS6BKW do not require any ground to operate as do most end fed type wire antennas. If you have a vertical it will usually require a ground plane of wire radials or wire mesh below it to be effective but a few have small built in ground radials like the Cushcraft R7, R8 and R9. These can work ok but a similar antenna with lots of wire ground radials will work better. Even these antennas do not require a connection to ground like a ground rod or water pipe to operate and grounding them will have no effect on performance.
In the US we have the National Electrical Code which requires any antenna feedline to be grounded in a certain way when entering the house. This is for human safety and has nothing to do with antenna performance. I suspect your country has similar rules. So get the HF radio, put up an antenna and operate!
When I read instruction it is written connect to ground, but I have not
thanks a lot for infoHi @braluca, the Yaesu FT-450D is a very nice radio. I do not own one but it has been on my radar for a long time. Unfortunately, Yaesu has recently announced that the FT-450D has been DISCONTINUED due to parts obsolescence. Here is an article that picked up on the announcement:
Yaesu FT-450D Discontinued – The SWLing Post
swling.com
If you still want one, you had better buy one soon before the suppliers' stocks run dry. Yeah, I'm sad too...
73 my friend, Dave K4EET
Don't give up yet! Both Universal Radio and Ham Radio Outlet here in the US are showing them in stock, so I suspect there may be vendors in Germany or the EU which still have stock as well.thanks a lot for info
truly a bad news, my dream now is spoiled
do you know any other similar radio?
It was perfect because little and with ATU inside
We've got one in our EOC. Decent, basic radio, although does not include an internal antenna tuner, so that's at least another $150 in cost to tack on.@braluca, while I do not know anything about this HF radio, a "cousin" to the Yaesu FT-450D might be the Icom IC-718.
IC-718 HF All Band Transceiver - Features - Icom America
www.icomamerica.com
It currently sells for USD $549.95 after rebate at GigaParts:
Anybody here have one of these?
Yes, for $100 more, pick up a used IC-7300. It will walk circles around the FT-450.thanks a lot for info
True, if you can find one used; very popular rig, I wouldn't give mine up for anything.Yes, for $100 more, pick up a used IC-7300. It will walk circles around the FT-450.
