markinnh03451
I have owned this 996p2 for a year or so now. I am on the edge of a desired reception area. A narrow slice of band width became un recievable when the lamp on the table where the scanner is had a led bulb in it. Then something changed and I could not hear a usually active frequency, so being the resourceful yankee I am, took the foil off the empty cookie platter and made a flag out of it on top of my back of set base loaded antenna. (I dream of a roof peak antenna), The foil flag made a difference. That same bandwidth dissapeared again same as with the LED bulb. Took off the foil flag and layed it down on the table. Not only did the disapeared badwidth/frequency return, it was much more active and much clearer! Reception is effected by non contact collector/reflector?
Any thoughts from you in the know gurus?
Also, is P25 threshold settings a radio wide thing or system wide...some of my P25 is descrambling scambled! That was even hard to type.
Best Regards,
Best Regards,
